serial port
hi
im using  labview 7.1 , i need to turn on the dtr ready signal.  continuously it should be on .
in vb i have used comm1.dtrenable=true command
so that the signal will be turned on until i close my port.
the same thing i need to do with the lab view for switching the DTR Signal .
If you have a example vi please help me on this
thanks in advance
(3,493 Views)
(3,488 Views)
Hai is your problem solved? Please post back. If solved please mark my post as solution to your problem so that it will help others who are facing same problem and looking for a solution.
Thanks for your understanding,
Mathan
(3,429 Views)
