serial read and write simultaneously
i want to write to a serial port and simultaneously be able to read what is send back to the pc. over the same port.
is it possible to attach a visa read and a visa write to the same port number?
if so, can someone tell me how to do it.
if not, maybe there is another way of doing it in Labview 6.1
Message 1 of 13
(5,330 Views)
Stranger:
You need NI-VISA 3.0 or higher. This is from the readme:
"For a Serial INSTR resource, multiple sessions to the same port caused weird behavior if you tried to both write and read data simultaneously. This has been fixed."
You also need to open 2 separate VISA sessions to the same port because LabVIEW limits you to a single I/O operation at a given time on a given session. Not an unreasonable restriction, just something you need to know. Just set the "Open duplicate session" input parameter to VISA Open to TRUE.
Dan Mondrik
Message 2 of 13
(5,330 Views)
i dont have NI-VISA 3.0 or higher.
i have the visa deliverd with LabView 6.1.
is there any way of doing it with the older version, or is it a bug in that older version.
also i am quite new to programming in Labview. if anyone has any sugestions on solving this problem, i'd really appreciate it.
thanks in advance
Message 3 of 13
(5,332 Views)
Hi Stranger,
This was not a BUG! It was a limitation. This limitation does not exist in the newer versions of VISA.
You should be able to download the most recent version of NI-VISA.
Ben
Message 4 of 13
(5,334 Views)
Hi Ben,
where can i download the most recent version of
NI-VISA, and is it compatible with LabView 6.1?
Message 5 of 13
(5,334 Views)
Try this
http://digital.ni.com/softlib.nsf/webcategories/85256410006C055586256BBB002C0E91?opendocument&node=132060_US
I just strarted at NI's home page and chased down the links under support.
Ben
Message 6 of 13
(5,334 Views)
hi,
i have downloaded and installed NI-VISA 3.0.
and it still does not work.
i want to be able to read and write to the serial port simultaniously. is it possible to address the TxD & RxD lines sepperately.
i've attached my program, and hope someone can tell me what i'm doing wrong.
Message 7 of 13
(5,334 Views)
Sure, you're not opening 2 references like you need to do, as described above. Each usage should call VISA Open first.
Dan Mondrik
Message 8 of 13
(5,334 Views)
i've done wat you said, now i get the following error message:
error code: �1073807339
"Timeout expired before operation completed."
i've tried to increse the timout (even to 20 seconds) but the error remains.
i've attached my program again to clarify
thanks in advance.
Message 9 of 13
(5,337 Views)
You still didn't have 2 sessions because you didn't pass "T" to "Create Duplicate Session". Also, explicitly calling VISA Open after it's been configured doesn't guarantee that the port remains in the same state. So I took the liberty of moving a few elements around in your diagram. What I have attached should work now.
Dan Mondrik
Message 10 of 13
(5,334 Views)
