set current level, OCP in hpe363xa drivers
I'm useing the agilent 3634a DC power supply in constant current mode. I don't see in any of the supplied drivers, one's that set the OCP or the current level. I do use the 'set OVP' and 'set the voltage level', along with the 'set current limit'. Did i miss them? or do I try to monkey with one of the others to make it set the current level and OCP? or do I just write the string to the device using the file I/O write? If I do that last option, do I mess up the drivers at all?
(3,639 Views)
hi, I am using E3631A instead. However, you may wanna read on for some hints.
___________
I used [HPE3631A Configure Output.vi] for setting the Initial Voltage & Initial Current Limit levels.
Later, to make changes only to the Volatge setting, I, again, used [HPE3631A Configure Output.vi] with "Current Mode" wired to "TRUE"
(I think it should be the same for setting the Current)
Would you try this?
Best regards
ian.f k
PS: Hope this helps.
Ian F
Since LabVIEW 5.1... 7.1.1... 2009, 2010, 2014
依恩与LabVIEW
LVVILIB.blogspot.com
(3,639 Views)
Hmmm, so I looked, and I don't see a 'Configure Output.vi'. only a 'Configure Output Range' (which will let me set a current or voltage range) and a 'Configure Output Enabled', but I want to set the current level the power supply is trying to drive in CC mode and the OCP. on the front panel I do this by makeing the the voltage limit very high, and the current limit low, then dialing up the current. So I could sneak and do this with the 'Configure Output Range' but I'm still not sure how to programmatically set the OCP useing the drivers. Thanks for the comment though.
(3,639 Views)
I can now see the different.
Well, perhaps you may need this info next time.
Take care and good luck.
Ian F
依恩与LabVIEW
(3,639 Views)
