05-09-2007 01:43 AM
05-09-2007
06:57 PM
- last edited on
05-16-2026
08:22 PM
by
Content Cleaner
05-09-2007 07:06 PM
05-09-2007 09:36 PM
You're making it way too complicated. You get dt from the Read Waveform function. You can then use the Build Waveform function to create a Waveform datatype that the Write LabVIEW Measurement File can handle. The Align and Resample is not necessary at all.
I put the change in the attached VI. I also cleaned up the upgly wiring.![]()
