splitting & plotting 4 channel data in one indicator
Hello all
           How to split 4 variables that are being displayed in one indicator?......I am reading data from a microcontroller serially...microcontroller acquires data from 4 channels all of which are temperature readings...my aim is to plot these 4 temp.readings seperately....but as the output of "VISA Read" is only one string indicator in which all my 4 temp. are being displayed how to split/seperate these readings and plot them differently?...
Best regards
Message 1 of 8
(4,491 Views)
Is there a specific format for the data string coming from the microcontroller?  Are the data delimited with a tab or comma?  Are the temperatures a set number of characters?
We need to know the protocol in order to be able to help.
Message 2 of 8
(4,489 Views)
Temperature from microcontroller is  in ASCII format ...microctrler sends 1 packet of data with 4 temp.readings in it at a time.....each temp.reading is 7 bytes wide so in total 28 bytes come at a time through serial port  and after each 4 readings there is a delimiter "~" and then next packet of 4 comes......I am unable to bifurcate them......i am attaching a snapshot of my vi where all 4 temp.are highlighted and which are needed to be displayed seperately as temp 1,temp 2....etc...pls do the needful .
best regards
Message 3 of 8
(4,459 Views)
I forgot to attach the snapshot of my vi as mentioned in the previous reply...hence pls find the attachment here in this post.
Message 4 of 8
(4,449 Views)
Renaming a bmp file to jpg to get around the ban on posting bit maps is just rude. You dont really think that changes the file type, do you?
Message 5 of 8
(4,446 Views)
yeah Dennis...i really dint understand this ban!!!!...:-(.... .jpg is taking too long to upload!!..:-(
Message 6 of 8
(4,439 Views)
sku...
you didn't get the point. Instead of posting a bitmap picture of >4MB (that can take a while to upload) you should have converted the picture into a jpg (photo) or png (best for drawing/screenshot) format by using MSPaint or another software (usually by 'save as...' and then choosing the graphic format to save.. )
You end with 19kB instead of 4MB Smiley Tongue  (I used irfanview ..)
You should really learn that if you don't want to annoy other readers 😉
To your problem:
Read the string with visa and send it into a scan from string vi..
post you vi with some data in a string indicator (right click on the indicator after reading some data and click data operations.. - make current values default ; save the vi and post it here
Greetings from Germany
Henrik
LV since v3.1
Message 7 of 8
(4,426 Views)
Henrik....i have done d same...using save as i changed the format from .bmp to .jpg
Message 8 of 8
(4,411 Views)
