subvi error at error out dialog box
i using the driver supply by agilent to control the agilent 8163a lightwave multimeter. The problem i m facing right now is that when i run the program, the xxx.vi will pop up at the error out status dialog box. This problem occurs at all the sub-vi provide by Agilent.How can i solve this problem.
(3,200 Views)
I think the problem that you are seeing is due to the automatic error handler being turned on. For information about enabling and disabling this feature as well as other new features of LabVIEW 7.0, please see the LabVIEW 7.0 Upgrade Notes here:
http://digital.ni.com/manuals.nsf/websearch/E8D86CD680B0753D86256D2C005D8EA0
Hope this helps!
Steven B.
Applications Engineering
(3,200 Views)
