talker/listener
I need for a simulation bench to simulate a GPIB instrument.
I know all of the GPIB commands (text message) i can receive and i suppose to process.
How can i use the fonctions present in the NI-488 to perform my instrument simulation correctly. I mean my application is only a Talker/Listener application.
What i need to implement in my code ?
Message 1 of 8
(4,859 Views)
Your best bet is to use NI-Device. This product was designed to be used as a talker/listener.
Message 2 of 8
(4,858 Views)
My application is based on NI488.2 DDK and i problably cannot use NI-Device.
Is there any other method based on ibxxx functions only ?
Message 3 of 8
(4,858 Views)
The DDK ibrd and ibwrt do not perform any addressing on the bus. When Controller, your code needs to send the addressing commands using ibcmd. For Talker/Listener you don't send the commands, so the main concern is to determine the state of the interface.
You can poll the status and determine when the interface is TACS or LACS. Depending on the state you can call ibrd and ibwrt. That is how you would write a talker listener application.
If you were using NI-488.2 you would need to use only board-level functions. The 488.2 DDK only supports board level functions.
Note: NI-Device would be the best solution, since it is design specifically to implement 488.2 compliant talker/listener applications.
DiegoF
National Instrume
nts.
Message 4 of 8
(4,859 Views)
What operating system and microprocessor are you using for your application?
Message 5 of 8
(4,858 Views)
OS : QNX neutrino
Processor : x86
Message 6 of 8
(4,858 Views)
You should be able to port the NI-Device DDK to work on QNX. Otherwise, Diego's suggestion of polling for TACS/LACS and doing the ibwrt/ibrd would be the other mechanism.
Message 7 of 8
(4,858 Views)
I thing that Diego's suggestion is the best way for us to do what we need. But i am going to see about NI-Device.
Message 8 of 8
(4,859 Views)
