tcp/ip comm error help
Hey Kevin,
I agree that you should try to dig a little deeper into the termination characters in your messages. The first error code you were getting is due to a timeout which is most likely caused by not having a termination character. There needs to be a linefeed or carriage return. Hopefully this can solve the problem.
Here is an article about the second error code you were getting.
Hope this helps!
Joe S
Message 11 of 13
(915 Views)
Thanks all for the replies.  Somehow the comms are working now!  I was able to start communicating with the device using VISA test panel and using my VISA comm vi that was attached earlier in this thread.
The problem that I am having now is knowing how many bytes are available at the port during VISA read operations.  Since I am communicating over TCP/IP the "bytes at port" serial option didn't work.  My vi executed without error when I knew how many bytes to expect and add this to the VISA read block.  If I requested more bytes than were available the system read the write values but then timed out waiting for the bytes that weren't ever going to come.
Is there a good way to dynamically specify how many bytes the VISA read command should use?
Kevin
Message 12 of 13
(912 Views)
The majority of the time you have no idea how much data is coming back that is why we set a termChar and enable it. Generally the termchar is linefeed and that is the VISA default but in your case you have this Lantronix LAN-to-Rs232 converter in between so no idea what the termchar maybe. Run NI-Spy or Wirshark and see what the last char that is read.
Message 13 of 13
(894 Views)
