tektronix labview 8.2 error
hi
I have installed driver for tektronix labview 8.2 with lab top and usb wire
then i used the example in the driver to acouring the signal
but the laptop shows one messege that (tektronix is CAMIRA NOTWOTK SCAN)
and the driver of camira started  defined tektronix as camira
any help please
the error  is
Error-1073807346 occured at VISA open  in
Tektronix TDS 200 1000 2000 Series.lvlib:Error
Query.vi->Tektronix 200 1000 2000
Series.lvlib:Autosetup.vi->Tektronix TDS 200
1000 2000 Series Acquire Waveform.vi
Possible reason(s):
VISA: (HEX 0xBFFF000E) The given session or object reference is invalid.
 any help
(4,360 Views)
please post your vi with the current values (during your test) made current values.
now I can only guess what you filled in for the visa resource name.
And another question what bus are you using, serial, gpib or tcp/ip?
greetings from the Netherlands
(4,340 Views)
thank you for respone
i used the oscillscpe driver example
in beganing it worked for 2 days then stoped
i using serial usb
(4,324 Views)
 its same that me ( FAHEM or H C U)
(4,322 Views)
Hi
This is probably a hickup in the serial interface,
Not all usb serial lines are correct.
Also the 10 ms timing is probably much too short. The transport of a waveform takes probably more time.
Chaeck also if your system looses memory in the task manager. If memory is full all programs get problems.
(4,308 Views)
hi
in fact that problem happend when i used another Tektronix oscillscope
so i return the previous Oscillscope
and it worked properly
thanks
(4,297 Views)
