time/div control , volt/div control
Hello! I would like to ask how can i control the time/div and volt/div parameters through labview8.0. I am using the tds 3052 oscilloscope and i have downloaded the appropriate drivers.I want to change the V/div through my computer and see the change on the oscilloscope sceen.Any Help;;;thanks a lot!!
(7,518 Views)
Configure Channel sets the vertical and Configure Acquistion Record sets the horizontal. Just like the example for single channel waveform acquire (Help>Find Examples>Hardware Input and Output>Instrument Drivers>LabVIEW Plug and Play). Turn context help on to see a description of each function in the driver.
(7,515 Views)
So, if i want to have 200mV/div and 10ns/div how can i manage it; through vertical range and time per record;can you give me an example;and something else regarding the tds settings. i want to have the average 32 in the "Acquisition mode" and for the MEASURE->Gating Cursors->Between VBAR Cursors..Any advices;; thanks for the help!I am honestly gratefull.
(7,513 Views)
Accepted by topic author Dead Poet
(7,491 Views)
I did give you an example. Unlike the knobs on the scope, the VIs allow you to set the entire range. So, if you have 10 divisions and you manually set it to 1V/division, you have a 10V range. That's the same as the default in the above mentioned example.
(7,464 Views)
Everything OK!!thank you very much!!!As for the acquisition mode, the averages, the gating and the cursors i found the apprpopriate vis in the driver. there are all in there!Thanks again!
(7,445 Views)
