timeout operation serial interface
I am interfacing instrument simulator using serial cable rs232.whether i use VISA  or I/O ASSISTANT, "timeout expired before operation completed" ERROR  is appearing.I have downloaded some vis from ni also,BUT the same error is showing up.
The write vi is where the error occurs.
(3,425 Views)
It's pretty unusual for a timeout error on a write. Do you have handshaking enabled?
A timeout on a read is common and can have numerous causes. You might be sending the incorrect command, you might be sending correct command but not terminated correctly, you might have a mismatch in com settings, you might be using the incorrect serial cable.
Before trying any LabVIEW code, debug your serial writes and reads with a program like Hyperterminal.
(3,422 Views)
