tnt 5002 interface
Are you using iblines through ibic or some other software? What exactly is the output of iblines?
Message 61 of 151
(3,172 Views)
I thing i use ibline true CBIC 32, I thing CBIC is the name of the software
the output of iblines is   EOI  ATN  SRQ  REN  IFC  NRFD  NDAC  DAV
and the value are            0       0        1        1       0        0           0        0
Message 62 of 151
(3,167 Views)
Is this the PCI-GPIB you are using?
Message Edited by Collin M on 11-15-2006 09:26 AM
Message 63 of 151
(3,165 Views)
No, the which I use hat this specification,  PCI MATCHMAKER S5920Q  0407  A014 (AMCC)
Message 64 of 151
(3,146 Views)
No, the oneI use hat this specification,  PCI MATCHMAKER S5920Q  0407  A014 (AMCC)
Message 65 of 151
(3,143 Views)
Who is the manufacturer of the PCI-GPIB?
Message 66 of 151
(3,141 Views)
Can you reply with the manufacturer of the PCI-GPIB, the driver, and the CBIC32 application?
Message 67 of 151
(3,133 Views)
the manufacturer off the pci Gpib, the driver and the CBIC32 is
company:Measurement Computing Corporation
# Company Information
phone1:(508) 946-5100
fax:(508) 946-9500
address1:16 Commerce Boulevard
address2:Middleboro, MA 02346 USA
email:info@MCCDaq.com
website:http://www.MCCDaq.com
default:\GPIB_32
the pci-gpib look exatly like this  .. Schematic attach..
Message 68 of 151
(3,120 Views)
Cant it cause problem when the PCI-GPIB  and the TNT 5002 are from to different manufacturer ?
Message 69 of 151
(3,099 Views)
Using equipment from two different vendors should not cause a problem.
I'm going to try to get a similar setup here. I'll let you know what I find.
Message 70 of 151
(3,078 Views)
