to control SC10 and SH05 with VISA serial
I am having a problem of communicating with the hardware.
I trying to control shutter controller(SC10, thorlab) and shutter(SH05/M, thorlab) by Labview.
I partly succeeded in communicating between Labview and SC10(with VISA serial function), but I don’t know how to open/shut the SH05.
The node of SC10 has four inputs, like an attached jpg file. How can I apply it?
(3,046 Views)
You should ask ThorLabs for the documentation for their APIs. Once you have that, if you still have trouble with your code then POST THE CODE (Not a picture of it!) and perhaps someone can help.
There's also a download site for the SC10 shutter controller that mentions LabVIEW drivers.  https://www.thorlabs.com/software_pages/ViewSoftwarePage.cfm?Code=SC10
There's probably similar for the SC5, I'll let you look.
Craig
(3,029 Views)
The SH05/m manual in Chapter 3 mentions that all control of the SH05 should be via the SC10 using the 6-pin port.  If you read the SC10 manual, section 4.3 & 4.4 gets into the connections and remote control of the instrument.  Try using a simpler VISA interface by using this snippet and feed the VISA resource name with the VISA Configure Serial Port vi.  Setup the port configuration as specified in the manual.
Help the Community (and future reviewers) by marking posts as follows:
If it helped - KUDOS
If it answers the issue - SOLUTION
(3,021 Views)
