transfer string data into double float type in serial communication
Currently , I am doing some labview programming by using one laser displacement sensor(position data unit:mm), and I could receive the data from the COM port, but they are in the string format. I need to display them in the waveform. I use the block of 'string to unsigned byte array', but the data were transferred into ASCII code. So, how can I use labview to obtain the real data just the same as that the sensor reads??Thx!
Smiley Sad
(3,289 Views)
On your string palette, you have Scan From String. You have additional conversion functions such as Fract/Exp String to Number. I prefer Scan From String but Fract/Exp String to Number can be used on an array.
(3,280 Views)
