You do not need NI-488.2 drivers to talk to the GPIB-232CT-A in S mode. This is because it is simply a serial instrument in this mode. Have you gotten the device to work at all in S mode? A good way to check this would be to use a Windows PC and use Hyperterminal to talk to the GPIB device. Refer to http://digital.ni.com/public.nsf/websearch/61BA0EE248FB0B328625660B0066858D?OpenDocument for more information on how you can do this. If you are not able to do this successfully, then we may have an issue with the hardware. Please try this and let us know if you have any problems. Hope this helps.
Anu Saha
Anu Saha
Academic Product Marketing Engineer
