trying to communicate with a machine through RS232 interface.
HI, love to see the problem solved by the team.....I had similar problem, and I am new to these forum nad also new to NI software. If yoy dont mind I am asking..What is MAX?
Thanks.
Message 11 of 16
(1,336 Views)
Measurement & Automation Explorer. It should be on your desktop.
Message 12 of 16
(1,328 Views)
Hi, Thank you Dennis,
perhab you could be my saver. I am trying to communicate a machine called U2000 Hitachi spectrophotometer  to a pc as a mean of store and collect data. the only port available in the machine is RS232C dp25. My link from pc is thru USB to serial adaptor. If I am using labview as a mean of programming software, what sort of the best solution that you can think off ?
Thank you
Message 13 of 16
(1,324 Views)
Thank you
What "best solution" are you talking about?
You have the software and you have the hardware. What more do you need?
Message 14 of 16
(1,313 Views)
Hi guys,
As I am mention before, I am new to these Labview..... I need someone to guided me thru the usage of these software..I am sure a lot of expert out there to help me...
thank you..
Message 15 of 16
(1,303 Views)
