tunics Plus .llb drivers
Hello
I have problems  to install manually the .llb provided by the Tunable Laser Source: Anritsu Tunics Plus. It seems that the library hasnt been recognised  and the icons do not appear to start creating a VI. Is there any standard procedure to do that ?
Labview 8.5 version
Tunics Plus CL   (Model : 3642HECL
Rafael
(5,179 Views)
Not sure at all what you mean? Are you talking about the functions appearing on the Instrument Driver palette? I don't know where you got the driver from (and that would be nice information to have) but if you create a subfolder in the instr.lib folder and place the driver there, everything should appear on the palette when you start LabVIEW.
(5,178 Views)
After a couple of restarts it worked but I have another problem. The .llb provided by Tunics is for Labview v.5.0 and I have Labview 8.6 .Unfortunately, there is no backward compatibility between 5.0 and 8.6. Do you know a way to upgrade my files to be usable in v8.6 ?
Thanks a lot.
(5,155 Views)
The old thread for this very common request was getting pretty long so post them here.
(5,149 Views)
 I have already received the upgraded drivers using the link you,ve posted on this thread. However, when I build a chain with Tunics components in the block diagram and I run it ,  a visa error code appears . Any Block diagram does not work.
The description is:
Error -1073807202 occured at Old visa Open in TUNICS Initialize.vi ->TunicsBasicSetting.vi
An screenshot is attached with the complete error description.
Any idea of what can I do ?
Thanks a lot,
Rafael
(5,087 Views)
2 things, in the TunicsInitialize you can replace this old visa open by visa open and perhaps you descriptor string not good yhink should be GPIB0::10::INSTR.
Regards
Greg S.
CNRS
LV 7.1 8.2 8.6 2009 2011 2012 2013 2014
LPMC - CNRS
N'oubliez pas de complimenter cela fait toujours plaisir.
(5,074 Views)
