unable to access ni-488.2m driver for windows 95 (gpibmngr.dll)
I wrote software to control an HP scalar network analyzer in windows 95, and it works fine. However, in trying to get the same software to run in windows 2000, I get an error: "unable to access ni-488.2m driver for windows 95 (gpibmngr.dll)" whenever I perform an action involving the GPIB interface (programming the SNA/grabbing data -- for example, when using the "Send()" proceedure in vbib-32.bas). The error box is titled "gpib-32.dll" I cannot determine why the drivers are having these problems in windows 2000.
(3,804 Views)
Hello-
Be sure to use an ibonl(ud,0) to take all unit descriptors offline before closing a program. Also be sure the GPIB card is functioning. After making sure you have the latest driver from (http://www.ni.com/support/gpib/versions.htm), the first step in determining the functionality of your GPIB card is to run the "Getting Started Wizard" found in Start/Programs/National Instruments/NI-488.2.
If the Getting Started Wizard Fails:
-Read the instructions on that utility.
-If you are using a PCI card, try switching slots.
-In Windows NT, you may want to verify your setup in Control Panel/GPIB. In this dialog, click GPIB0 and click "Board Type". Be sure that the board matches what is installed in your system. If you can't see the serial number see K
B#1N88Q5RM (http://digital.ni.com/public.nsf/websearch?SearchView&Query=1N88Q5RM)
-In other versions of Windows, you should be able to see the GPIB interface in the "Device Manager".
The next step is to communicate with the instrument in the Measurement & Automation Explorer (MAX). In MAX under "Devices and Interfaces" you should be able to find your card. Right-click and do a "Scan for Instruments".
If the scan fails:
-Be sure the instrument is powered on and online.
-Be sure the cable is connected tight and screwed on.
-Try switching cables. Shorter cables are preferred.
-If using multiple instruments, try communicating to one instrument at a time.
Randy Solomonson
Application Engineer
(3,804 Views)
Your answer was ineffective. My problem does not arise when I close the program, but when I am using it and attempt to communicate with the instrument. I will attach a picture of the error message, and you can see it arises after I press the "Initialize" button which attempts to send information to the instrument my GPIB card is connected to. This software DOES work in Windows 95, why not in Windows 2000?
(3,804 Views)
I found an issue very similar to this. Another customer had this problem when gpibmngr.dll somehow was deleted from his system folder. Reinstalling the latest driver from here solved the problem:
(3,804 Views)
