updating ip address in max
In driver session of ivi driver the ip adress of TCP/IP device has to be changed if the ip adress changeor it can be automated evry time the ip address dynamically changes?
thanks
(3,197 Views)
I'm not sure I understand what you're trying to update automatically. If you're referring to the IP address you provide to open the session, then there is no mechanism for automatically updating this. How is it supposed to know? If the IP address of the instrument is changed dynamically, then it's getting the address from a DHCP server.
(3,183 Views)
