upgrade from labiew 6 to 8 and getting a visa error with usb to gpib.
I just upgraded to Labview 8 from Labview 6.1.  I had a program that talked to a power supply by a usb to gpib device and it worked fine till I upgraded.  Using the visa write function and get error #1073807195 occured at VISA write
possible reasons:
VISA: (Hex 0xBFFF00A5) The interface type is valid, but the specifed interface number is not confiqured.
The name is GPIB0::16:INSTR, and it is a Agilent 82357A USB/GPIB
The interface number for my device is set to 0 and the default for labview is 0.  The device still works because I can send it signals through the software that came with the GPIB.  Everything seems set to channel 16.  I can't find the problem any help would be much appricated.
(3,274 Views)
Hi needbe19,
When you installed LabVIEW 8.0, did you install the Driver CD that came with it?  This Driver CD will install a newer version of NI-VISA that supports LabVIEW 8.0.  You will need to reconfigure NI-VISA in the Measurement & Automation Explorer to be able to use your Agilent USB/GPIB controller.  Here is a KnowledgeBase article that describes how this is done.  Be sure to only use the Agilent Libraries upto version 14.0.  Version 14.1 has known incompatibilities with our NI-488.2 driver.
(3,262 Views)
