usb 6501 and pyvisa
Hi
I'm trying to control the I/O of the USB 6501 device from NI via pyvisa. I can launch the test part from NI max and it works well. However when I want to see the device with ResourceManager() with pyvisa,I can see all my devices in the list except this one.
Does someone has a clue for this problem ?
Configuration : Windows 7, Spyder (Python 2.7), NI-DAQmx 9.9.0f0.
Message 1 of 8
(6,433 Views)
It's not accessible with VISA. It appears in MAX because you installed DAQmx, which is the driver you must use.
Message 2 of 8
(6,404 Views)
You mean that I can't use pyvisa to control this device ?
Message 3 of 8
(6,376 Views)
That is exactly what 'it's not accessible with VISA' means. Why did you think it was a VISA compatible device?
Message 4 of 8
(6,373 Views)
I have absolutely no idea about it, I'm pretty new in this section, just wanna see if I could control it with python
Thank you for your help anyway
Message 5 of 8
(6,367 Views)
I said you couldn't use VISA. I didn't say you could not use python.
Message 6 of 8
(6,359 Views)
How can I use python to use an USB-4431 without pyvisa ?
Thank you.
Sorry if the answer exists already, I am quite a beginner..
Message 7 of 8
(6,151 Views)
Search the boards for 'python daqmx'.
Next time, start a new thread for your questions though a dedicated python forum might be more appropriate.
Message 8 of 8
(6,139 Views)
