usb gpib hs with matlab
how to controll a USB GPIB HS interface with Matlab?
should I create a GPIB object?
(3,211 Views)
hi pablo,
From NI we cannot help you because of this is a MATLAB issue, anyway I encourage to anyone on the forums that had worked with that to try to help you.
I recommend you to ask this directly to Mathworks, probably they would be able to help you. You can also look for something at the website of Mathworks:
http://www.mathworks.com
good luck,
Jaime Cabrera
NI Applications Engineer
Jaime Cabrera
NI Applications Engineering Spain
(3,173 Views)
