usb to rs485 converter
I need to know if the NI USB to RS 485 converter has the ability to configure individual ports for 2 wire and or 4 wire operation independantly?
(3,902 Views)
Yes! The USB-485 ports are all individually controlled, so you can configure each one either through the device manager or by making an IOCTL call from software. Everything is independant.
(3,902 Views)
is there a speed increase with going to USB from RS-232? or is it pretty
much defined by the device you're connecting to?
"Chris Rake" wrote in message
news:506500000005000000FAD10000-1042324653000@exchange.ni.com...
(3,902 Views)
Are you referring to connecting directly to USB capable equipment? Or connecting to RS-232 capable equipment using a USB-232 convertor?
(3,902 Views)
