use gpib-32.dll with visual basic .net
I want to use the GPI-32.DLL with visual basic .Net.
But I've somes problems :
When I Use the function ibrd32, i can't received the String read by the function
My function is declared as :
Declare Function ibrd32 Lib "Gpib-32.dll" Alias "ibrd" (ByVal ud As Integer, ByRef sstr As String, ByVal cnt As Integer) As Integer
When I receive a string Visual Studio say me that :
Une exception non gérée du type 'System.Runtime.InteropServices.InvalidOleVariantTypeException' s'est produite dans b_ieee.dll
Informations supplémentaires : Le variant OLE spécifié n'est pas valide.
How I will do for reveive correctly my string, What il the correctly declaration ?
Thanks For your help
PS : Sorry for my very bad Eng
lish I'm French
(5,681 Views)
Sorry I still haven't used .net so this is a guess. What happens if you add the word "Ansi" to your declaration:
Declare Ansi Function ibrd32 Lib "Gpib-32.dll" Alias "ibrd" (ByVal ud As Integer, ByRef sstr As String, ByVal cnt As Integer) As Integer
(5,681 Views)
The gpib-32.dll needs to be upgraded.
It doesn't have a good hand shaking with .Net string structure.
(5,681 Views)
You need to use a wrapper around the definitions and to define the string as a VB string. see example below
'Definition of buffer
Const ARRAYSIZE As Short = 1024 ' Size of read buffer
Dim ValueStr As New VB6.FixedLengthString(ARRAYSIZE)
'call to ilrd
ilrd(Dev, ValueStr.Value, ARRAYSIZE)
'defintion in VBIB-32.VB
' NI-488.2 DLL entry function declarations
Declare Function ibwrt32 Lib "Gpib-32.dll" Alias "ibwrt" (ByVal ud As Integer, ByRef sstr As String, ByVal cnt As Integer) As Integer
I have downloaded a sam
ple simple GPIB project to the ni developers exchange.
if you forward me your email I will be happy to email you the zip.
Kevin@kotech.demon.co.uk
(5,681 Views)
