using PC to control Omega mass flow controller
I have 3 Omega MFCs mode No FMA 765 but I have not Indicator and controller, now I want to use 1 PC to control all of MFC simultaneously (by com port). Can I do it and I don't know what software can I use (maybe Labview).
(3,771 Views)
What is "MFCs mode No FMA 765", and what does "have not Indicator and controller" mean? Do you have documentation on the device? Does it actually have a serial interface? If so, then you can control it from LabVIEW. You will need to look at the device's documentation to see what the communication protocol is.
(3,753 Views)
