using a cheetah driver
I'm using a cheetah driver for as master device and want to configure it
All the examples is pretty confusing [ PNG attached] and can't find any relevant usage of the file and I see the error message as Error 8010 occurred when ever I try to execute one of the examples.
All I want to do with this driver is to  setup it as master device with mosi clock input and chip select
please help
(1,323 Views)
Naive question, what is a cheetah driver? if you could explain that maybe a larger audience could help you or you are limited to the folks who are familiar with "cheetah driver"
BTW, png is not attached.
Santhosh
Soliton Technologies
(1,286 Views)
