using keithley 24xx
I am controlling a keithley 2400 source Meter. By using the keithley 24xx software.
under examples I selected
Keithely 24xx ReadMultiple.vi
When I source 0.0000007 A
the program sources 0.000001
I located the problem in the configure output.vi
(see attachment)
As you can see by sourcing 7E-7 A the program writes 0.000001A to the Source Meter.
How can I change the output string to 7E-7.
Thank you
(4,507 Views)
Accepted by topic author hanna80
Change the constant string in input to the vi "Format value" (the vi where "Output value" is wired) from "%s;:" to "%g;:".
This should work
Bye
CLD - Labview Certified Developer
(4,496 Views)
