using serial port of a desktop PC to control an external device connected to it using LabVIEW
Hi all
I am controling an extrenal device connected to the serial port of a desktop PC using LabVIEW , the theroy of  my work is  that when that the extrenal device will perform an action , then it will send "A " ASCII character to the serial port of the Pc to acknowldege that it has finshed its action , when the PC recives an " A" ASCII character  from the serial port using the LabVIEW program atttached with my post , it will perfom the additon of two numbers , if not it will subtract the two numbers , if the "A" character recived  and after performing the additon process it must send a " B" ASCII character ( write )  to the serial port and when the external device recives the  " B "  ASCII character it will  resume doing its action again, it seems that  ( writing ) to the serial port is not done and I dont know why , and also when I check about the " A" ASCII character , there is an error message
attached is my LabVIEW porgram and what shows as an error , could any one help me with this problem
thnaks alot
(3,529 Views)
sorry forget to attach the LV program and the error picture
(3,524 Views)
and  the LV program also is here
(3,522 Views)
a short look at your code:
1- serial init should be done once at the beginning, before you enter the loop
2- you want to read one character, but you configured the visa read to wait for 7 bytes -> timeout error, so even when your 'A' is received the 'B' will not be send
3- where is your VISA close? (once when program finish)
Message Edited by Henrik Volkers on 07-31-2006 02:11 PM
Greetings from Germany
Henrik
LV since v3.1
(3,491 Views)
