using tektronix scope results in timeout error?
I am measuring on channel 1 and gives the command curve? to send the curvedata to Labview. when I want to switch the scope to channel 2 and give command curve again for sending the channel 2 curvedata to Labview I get a timeouterror in instrumentI/O assistant. very strange I think? Why is it working on channel one but not when I switch channel(from the program)?
TDS220 is the scope. (GPIB instrument.)
Help please, regards Fredrik
(3,265 Views)
I solved it!
(3,257 Views)
