varian multigauge controller
The first info to give is which instrument,
and what are other busoptions, and especially is there a usb driver layer from the manufacturer.
I don't mean a LabVIEW driver but a usb communication layer.
greetings from the Netherlands
Message 11 of 25
(2,843 Views)
in our system, we use fieldbus with USB card. The instruments are connected with this card, the connector is USB.
I try to make sure first, by using labview7.0, I can find USB device in MAX, however, I can't do this now. Could you let
me know how to do this? Is there any way to do that?
If I can do that, I think I may try to next step, communicate with my instrument by serial usb VISA.
many thanks.
wx
Message 12 of 25
(2,847 Views)
In this case the fieldbus card is the device and this one has a usb driver.
Don't try to find this usb device in MAX and try to communicate with it via USB RAW.
USE the driver that you find in the device manager and that one offers a shell for accessing devices on the other side of the bus.
USB is here only a means to get to the devices.
Message 13 of 25
(2,828 Views)
Albert,
Thanks for the info. I never use USB before, could you paste some subvi for example. I use labview 7.0
, later vi can'b open.
thanks.
wx
Message 14 of 25
(2,826 Views)
wx,
For more information related to USB Raw, please reference the following KnowledgeBase: How Can I Communicate With a Device Using NI-VISA USB RAW Mode?. You could also reference another Discussion Forum: USB Raw Bulk communication, that you might find has some great reference material.
Hope you have a great day.
Sarah S.
Applications Engineering
Message 15 of 25
(2,807 Views)
Hi
Sorry for the easy to misunderstand email earlier today.
I tried to say, Don't try to find this usb device in MAX and DON'T try to communicate with it via USB RAW.
Just try to find the fieldbus driver for the card, preferably with varian drivers for the multigauge controller.
Just think of usb as a miraculous way that works.
Message 16 of 25
(2,801 Views)
I don't know how to input instrument address by usb indeed. Could you show some example the format of
usb address so that I can test in my computer. my labview is 7.0 version. thanks
Message 17 of 25
(2,774 Views)
tangwenxin,
From the previous posts, the following Developer Zone Tutorial: USB Instrument Control Tutorial may help you in getting started.
Hope this is able to help.
Sarah S.
Message 18 of 25
(2,757 Views)
Hi
Do not concentrate on USB,
Look for fieldbus and how to address that, Maybe you have some documentation for your fieldbus card or for your controller.
Message 19 of 25
(2,741 Views)
good idea. The questions is, since I use labview7.0, many advanced funcation is not available. Therefore, I hope to do this
from low level. At this point, I was stucked. I don't know how to achieve this kind of instrument and what's the string formate
for fieldbus.
Message 20 of 25
(2,739 Views)
