vbsicl32.dll
My Program VB6 state "can't find vbsicI32", but it is in Win98 system folder?
(9,889 Views)
None of the NI drivers install or use this library. In fact, this sounds like the VB language interface file for the HB driver (SICL)for the HP-IB boards. You should probably contact HP (Agilent).
DiegoF.
(9,888 Views)
I had this same issue.  Apparently the program needed "vbsicl32.dll" AND another file called "sicl32.dll".  Without sicl32.dll, the VB6 program stated "can't find vbsicI32", even though vbsicl32.dll was in the correct location.
Copy sicl32.dll to the windows system directory and the error should not come up.  You do not need to register these dll's.
(9,728 Views)
Hi I have the same problem If somebody know how to resolve please send me email rcruz@amigotecnoligia .net
(8,806 Views)
At the target runtime PC, you should install Agilent IO Libraries instead of NI-VISA or NI-488.2 software. The DLLs are very specific to Agilent SICL modules.
(8,801 Views)
Good the problem was resolve
I download the file 1_IOLibSuite_15_0 the web page and install after that the was resolve
(8,781 Views)
vbsicl32 is just for agilent io connection. how about if you are using ni visa. can anyone tell the specific dll file to open instrument? im trying to connect vxi-mxi2 using nivisa. please help. thanks!!
(6,582 Views)
