viEnableEvent returns VI_ERROR_TMO, TCP/IP connection
I am having trouble enabling events for a callback handler on my Tektronix Scope. I Install the handler, enable the SRQ bits necessary, and then enable the event, but when my code calls viEnableEvent, it returns a timeout. I have attached the NI I/O Trace of the sequence of events.
Thanks in advance for your help.
(2,766 Views)
Hi, were you able to solve this issue ? I'm facing the same problem, thanks
(1,585 Views)
