virtualization of a PCI GPIB ?
Has anyone ever successfully installed a PCI GPIB on a virtual machine?  I am specifically trying to run an XP virtual on a Win7 64bit host.  I am using "Virtual PC 2007 SP1".  The host has a PCI GPIB card that works fine.   I can install the drivers, and see the card on the virtual, it won't actually communicate with it.  The GPIB is not a NI but am willing to buy NI if it works.
I can't find much on the web about PCI cards and virtualization.  There is very little documentation which leads me to believe it works.
BTW, the host is an embedded system in a *very* expensive piece of hardware.
-neal
(6,838 Views)
Hello Neal,
I do not beleive that it is possible to get a PCI-GPIB device to work on a virtual machine. Our PCI-GPIB devices will work on Windows 7 64 bit machines though. It just will get installed on the emulation layer. Please let me know if you have anymore questions. Have a great day!
Best Regards,
Adam G
(6,810 Views)
Have you ever tested it on HyperV?  I hear it has better IO virtualization. (IOV)   -neal
(6,804 Views)
Hello Neal,
I have never tested this on HyperV. I am not sure if it will work. Since it is another virtualization software I am not sure it would even work. You should not have a problem, though, using it on your Windows 7 machine you have now. Has anyone else used HyperV?
Best Regards,
Adam G
(6,768 Views)
You are not going to be able to use a PCI-GPIB (from NI or any other vendor) in a virtual machine, including with HyperV. As Adam said, you can use your PCI-GPIB natively in Windows 7 64-bit. We do not specifically test or support any of our GPIB interfaces on virtual machines, but I know that many people successfully use our GPIB-USB-HS in virtual machines. I have personally used it in VmWare, but other VM platforms may work as well.
I know that it is not compatible with Virtual PC, which is also what the Windows XP Mode in Windows 7 is based on. The best recommendation is to run your application natively in Windows 7 if at all possible.
-Jason S.
(6,721 Views)
IOV - - is the magic solution.
It appears that PCIe virtualization is either working, or in the near future, for 2008R2.  Here are some links on the matter:
   http://www.adminkernel.com/virtualization/what-is-sr-iov
   http://wikibon.org/wiki/v/IO_Virtualization
PCI bus virtualization, however, does notg appear to work now or ever. (I tested it on 2008r2) I may need to switch to a PCIe GPIB card.
-neal
(6,717 Views)
I started a thread talking about Virtual Machine advantages with a challenge for NI.
forum thread: PCI Passthrough with Virtual Machines
(6,154 Views)
