visa clear takes too long to run
In some computers "VISA Clear" takes too long to run. Why?
(4,241 Views)
Could you give more details about it?
For example, what is your system configuration? your application (PXI or else)?
What do you mean by "too long"? Do you have any time estimation?
Celine
National Instruments France
(4,216 Views)
10 s to execute
Moxa Nport 5410
XP SP3
LB 9
NI-Serial 3.8.2
Daqmx 9.4_05
(4,196 Views)
Could you give more details about your application?
Celine
(4,187 Views)
Each 2 s I write 5 bytes and read 128, if I place a "clear" after the read, or before the write, I will wait 7 to 10 s
António
(4,178 Views)
The default timeout is 10 seconds. It sounds like something may be timing out.  Put an indicator on the error wires to see if any errors are occuring.
Lynn
(4,160 Views)
No it is not. At the computer where I am replying now, I have the application running with clear without problems
(4,154 Views)
