visa exclusive lock hislip
I try to use VI_EXCLUSIVE _LOCK for accessing HiSlip device over TCPIP (R&S CMW500)
What I did is to test the application locally ( 2 instances of same application running on same PC): it works as expected (both for SOCKET and for HiSlip)
Then I moved to use HiSlip, because SOCKET is not supposed to work for LOCK on different machines
When I tested real application ( 2 application running on different machines) I got following result:
- at the beginning it look as it is working: lock works and second machine is waiting for access granted
- after timeout of about 10s (very similar to default timeout for communication) the viOpen(..VI_EXCLUSIVE_LOCK,60000) returns with an error ( resource locked). Why 10000ms and not the 60000ms expected?
-after some loops of testing, the resource appears locked EXCLUSIVE, and I can not access from neither first or second machine
-closing the application or rebooting machines does not help: only found solution is to reboot device
I'm using NI-VISA 14.0 and NI-488.2 14.0.0 from a C++ application.
(4,457 Views)
Dear Diegoba,
as you can read from third party driver download page, the instrument driver you are using is not supported by National Instruments.
This instrument driver is NOT supported or maintained by National Instruments.   This driver is maintained and supported by the instrument manufacturer or a third party.
Did you try to contact R&S technical support? Maybe they'll be able to help you in solving your issue.
Best Regards.
Cla_CUP
NI Italy
Technical Support
(4,434 Views)
