visa namespace between forms.
I am trying to pass visa namespace between forms and I am really stuck!
I cannot figure out why I can see the mainform property from the other form.
Can someone give me a shove in the right direction, Please?
Here is some psuedo code:
namespace instcontrol
class mainform
Public ReadOnly Property OpenedSession() As NationalInstruments.VisaNS.MessageBasedSession
    Get
        Return mbSession
    End Get
End Property
Private Sub btnOpenSession()
mbSession = CType(ResourceManager.GetLocalManager().Open(txtSelectedResource.Text), MessageBasedSession)
End Sub
Private Sub btnOtherForm()
        Dim Other as OtherForm = New OtherForm
        OtherForm.ShowDialog
EndSub
End Class
Class OtherForm
Private Sub OtherForm_Load()
If Not (InstrumentControl.MainForm.OpenedSession Is Nothing) Then
        PopulateSessionTreeView()
Else
Me.Close()
End If
End Sub
End Class
End Property
(4,450 Views)
Attached is an example that shows passing strings across forms. It is done for VISA resource names in the Simple Write Read example, located in the following folder.
C:\Program Files\National Instruments\MeasurementStudioVS2003\DotNET\Examples\Visa\SimpleReadWrite\VB
Check to see if your variable is public or private. In the Class View, you should see a lock if the variable is only accessible in its owning form. In the attached example, I declared a variable, PublicVariable, as public. You should be able to access it from Form1 (it is declared in Form2). The variable, TestVar, is private and is accessed to change values for the form using a property. It is not directly accessible by Form1 (it is also declared in Form2), but can be accessed through the public method. I hope this helps!
Missy S.
Project Engineer
RoviSys
(4,421 Views)
I did find another way to do it, and after seeing your example it all made perfect sense to this poor old vb6 programmer 🙂
I did it my way comes to mind here, but your way is much simpler and elegant.
My Way:
Class Main
Get
Return mbSession
End Get
End Property
  Private Sub btnBrowseVisaNS_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles btnBrowseVisaNS.Click
Dim BrowseVisaNS As BrowseVisaNSForm = New BrowseVisaNSForm
     BrowseVisaNS.Owner =
Me
BrowseVisaNS.ShowDialog()
  End Sub
End Class
Class BrowseVisaNS
  Dim mbsession As MainForm
Private Sub BrowseVisaNS_Load(ByVal sender As Object, ByVal e As System.EventArgs) Handles MyBase.Load
mbsession = Me.Owner
If Not (mbsession.OpenedSession Is Nothing) Then
Else
Me.Close()
End If
End Sub
End Class
Your Way:
.ShowDialog(Me)
Much less typing 🙂
Thanks for pointing me in the right direction with that one, I would have wandered around aimlessly for days before figuring it out!
(4,401 Views)
Glad I could help! Happy programming! Smiley Happy
Missy S.
Project Engineer
RoviSys
(4,387 Views)
