visa panel test for smc 100
I am trying to test SMC 100(a serial port device) using visa test panel.The
problem
is that i am unable to send commands to SMC. It works fine with the
software
they
provided. I checked the RS 232 cable, the port settings of my COM and my
device. But i
am unable to figure out the solution.
When i send commands the SMC (Stepper motor)  doesnt move but the return
status
is 0.
Also when i try Viread, it always shows a error BFFF0015(timeout error). I
am
also
using appropriate termination characters.
Please help
Message 1 of 11
(5,230 Views)
how did you check the cable?
greetings from the Netherlands
Message 2 of 11
(5,218 Views)
yes i did........its fine
Message 3 of 11
(5,213 Views)
HOW did you test, and is it a NUL modem or straight connection?
Message 4 of 11
(5,203 Views)
Use portmon to see what the vendor's program is sending and compare it to what you are sending.
You have not actually said what command you are sending, what termination character you are using, how you are specifying the termination character. You have not provided the instrument manual or a link to it.
Message 5 of 11
(5,196 Views)
sorry for the late reply....its a straight connection
Message 6 of 11
(5,162 Views)
I have encountered something interesting when i tested using portmon, there difference in the queue sizes. timeouts and handflow Xon and Xoff limits.(I have underlined them in my log file). And also when i execute the command using VISA test panel, it doesnt get executed but when i close VISA and open the user's software the command that i gave earlier using VISA test panel gets executed.
I am attching the user's manual, please checkout programming section for commands and syntax. As far as i know i am using the correct syntax
Please help.
Message 7 of 11
(5,155 Views)
Message 8 of 11
(5,151 Views)
I am sorry i couldnt upload the log file due to some error.
The following notable differences i noticed,when i send commands using VISA test panel:
354857  0.00000000  nimxs.exe  IOCTL_SERIAL_SET_HANDFLOW  Serial0  Shake:1 Replace:43 XonLimit:64 XoffLimit:64
354857  0.00000283  SUCCESS
354862  0.00000000  nimxs.exe  IOCTL_SERIAL_SET_QUEUE_SIZE  Serial0  InSize: 640 OutSize: 640
354862  0.00000074  SUCCESS
354863  0.00000000  nimxs.exe  IOCTL_SERIAL_SET_TIMEOUTS  Serial0  RI:-1 RM:0 RC:0 WM:0 WC:500
354863  0.00000098  SUCCESS
When i send commands using SMC  software:
354873  0.00000000  SMC100.exe  IOCTL_SERIAL_SET_TIMEOUTS  Serial0  RI:-1 RM:-1 RC:55 WM:0 WC:500
354873  0.00000199  SUCCESS
354887  0.00000000  SMC100.exe  IOCTL_SERIAL_SET_HANDFLOW  Serial0  Shake:1 Replace:43 XonLimit:1024 XoffLimit:1024
354887  0.00000278  SUCCESS
354888  0.00000000  SMC100.exe  IOCTL_SERIAL_SET_QUEUE_SIZE  Serial0  InSize: 4096 OutSize: 2048
354888  0.00000069  SUCCESS
The link to user manual for SMC 100 PP:
please check out the commands and their syntax in programming section.
Message 9 of 11
(5,146 Views)
I now understand that the vendor program works with the serial cable. So the cable is correct. And I  know now how you tested it.
Attach your vi so we can look at wire or other problems.
I don't believe that the initialisation is a real problem. Smaller buffers are OK in a parallel programming environment.
But the endcharacters have to be the same.
Message 10 of 11
(5,134 Views)
