visa read gps
I followed the following video as my GPS is made similarly:
https://www.youtube.com/watch?v=SebcpkbYBd4
Okay I am posting this as noone has been able to help me yet and I am still at a lost...
I am using a adafruit ultimate GPS with the following pin layout
Pin 1:  Vin
Pin 14:  TX
Pin:  10 RX
Pin 30  GND
Module specs:
  • Satellites: 22 tracking, 66 searching
  • Patch Antenna Size: 15mm x 15mm x 4mm
  • Update rate: 1 to 10 Hz
  • Position Accuracy: 1.8 meters
  • Velocity Accuracy: 0.1 meters/s
  • Warm/cold start: 34 seconds
  • Acquisition sensitivity: -145 dBm
  • Tracking sensitivity: -165 dBm
  • Maximum Altitude for PA6H: tested at 27,000 Meters
  • Maximum Velocity: 515m/s
  • Vin range: 3.0-5.5VDC
  • MTK3339 Operating current: 25mA tracking, 20 mA current draw during navigation
  • Output: NMEA 0183, 9600 baud default
  • DGPS/WAAS/EGNOS supported
  • FCC E911 compliance and AGPS support (Offline mode : EPO valid up to 14 days )
  • Up to 210 PRN channels
  • Jammer detection and reduction
  • Multi-path detection and compensation
And I keep getting the following error:
Any suggestions?
(4,464 Views)
Duplicate
http://forums.ni.com/t5/LabVIEW/GPS-and-Xbee/td-p/2742680/page/2
Please stick with one thread. You see were getting help there.
(4,460 Views)
