visa unable to find drivers
hi all i am having some problems with visa drivers , i am having following error
Labview : (hex 0xBFFF0009E) visa or a code library required by visa couldnt be located or loaded. this is usually due to a required driver not being installed on the system .
i know there is some problem with the driver but when i check my windows drivers in the device manager of the laptop it tell me the device is working fine .
also i was not getting this message a day before, and today when i tried to run the example this error pops up , i havent changed any settings
also i m using labview 2009 and my laptop is dell d830 with vista running on it
with regards
Regards
(3,681 Views)
Accepted by topic author nolsqn
The windows driver and device manager have nothing to do with VISA. Did you try a reinstall or repair?
(3,667 Views)
i fixed it by reinstalling the device drivers
thanks
Regards
(3,652 Views)
