visaic download
The LabView VISA tutorial document mentions an application called VISAIC that allows interactive use of VISA. However, the application is not available at the location mentioned in the article (ftp.natinst.com in the support/visa directory). All that is there are the drivers and development environment, both of which I have already installed. Where can I find the VISAIC program download?
(4,519 Views)
Hi Tyto,
If you have visa installed on your system, VISAIC should already be installed. You can get to it by opening MAX go to tools > VISA > VISA interactive. Or look in C:\VXIpnp\WinNT\NIvisa
Hope this helps out!
Best Regards,
Aaron K.
Application Engineer
(4,519 Views)
