visual basic error 48
I got : "run-time error 48, file not found: Gpib-32.dll" when I use
I currently installed a GPIB-AT card on my old PC. The operation
I got this error when using Visual Basic-6.0 on GPIB-AT card (Run Time Error 48 in visual basic "File not found: Gpib-32.dll"). I am using Winows ME.
I got this error when using Visual Basic-6.0 on GPIB-AT card:
(4,746 Views)
Hi you lack probably the Gpib-32.dll in the c:\Windows or
c:\Windows\System32 directory because:
- you did not install the NI-488.2 software ( probably )
- you installed another board that has a homonymous Gpib-32.dll with
other functions than NI (maybe)
To test it, you can install NI-488.2 and test the communication
afterwards.
f.grasdepot@labtab.com
(4,742 Views)
Thanks for your reply.
I did install the NI-488.2 before and already I have the GPIB-32.dll (and GPIB-16.dll & GPIB.dll) in c:\windows\system.
The "NI-488.2 GPIB software" works OK (however I didn't connects the GPIB card to any actual external GPIB device yet, but the: "Software/Hardware Diagnostic Test" and "Win32s Interactive Control" work OK).
HNas
(4,730 Views)
as far as I remember, there are dip switches on the GPIB-AT board for
selecting the IRQ,DMA and I/O address.
You should be ready to reboot several times to test several
configurations with dip combinations.
The simplest is to have a software for direct discussion with an
instrument connected to your board.
You can use an NI software like LabView or a simpler NI tool, for me I
use LabTab (www.labtab.com) which is free and has a toolbar for
directly sending "*idn?" or other strings to the GPIB bus.
You must be ready to reboot several times so the time to send "*idn?"
is of some importance and a simple tool is better.
The good news is that once this has worked, you will never do that
again and will not have to buy a GPIB controller ...
N.B. for instance, a voltmeter like AG34401A is perfect for such tests
With some luck, there will not be many reboots before finding a good
configuration especially if you remove any other PCI and ISA bords from
the PC , sound boards , etc ... ;=)))
F.grasdepot
(4,704 Views)
Thanks a lot for your help.
I have changed the GPIB dll files (gpib-32.dll  &  gpib-16.dll) in the "c:\windows\system\" and fortunately my VB application now works OK. The previous version of dll files were installed by NI-488.2 with the following detalis
  • gpib-32.dll    size=100KB, Date:4/5/1994
  • gpib-16.dll
 with the
(4,699 Views)
I have changed the GPIB dll files (gpib-32.dll  &  gpib-16.dll) in the "c:\windows\system\" and fortunately my VB application now works OK. The previous version of dll files which were installed by NI-488.2, have the following details:
  • gpib-16.dll    size=26.8KB, Date:4/4/1994
 The new dll files from COMPACT12 (from NI), have the following details:
  • gpib-32.dll    size=25.5KB, Date:4/12/1996
  • gpib-16.dll    size=11.5KB, Date:8/9/1995
Thanks again,
HNas
(4,696 Views)
