want to send data through labVIEW to arduino using visa write and the process and take steps using arduino. A
@Jerson_Jose wrote:
how do I send a Boolean value to an Arduino digital port using VISA Write if it only accepts strings? The Boolean value will open/close the valve connected to the digital port of Arduino.
Thank you.
Use Format String to put the boolean into an ASCII representation of some kind.  Most commonly, I see "%d" for the format which will turn the Boolean into a "0" or "1".
Message 21 of 21
(551 Views)
