waveform chart propert node
Is is possible to get the current x position of the waveform chart...maybe using the property node?
Thanks in advance,
AH
(3,445 Views)
Hi AH,
If the x-axis scrollbar is not being used, the current x position of the waveform chart is simply the maximum value on the x-scale. First, make sure to turn on Autoscaling on the X-axis via the Waveform Chart property XScale.ScaleFit with a ‘2’ constant wired as input. Then, to read the current x position, use the Waveform Chart property XScale.Maximum.
Another option is to use the initial x-axis value (XScale.Offset) and add the length of the chart history data to that value. However, note that this only works is the chart history buffer is not full. Or, just have another variable that tracks the number of data points that have been outputted to the chart and add that value to the XScale.Offset.
Hope this helps. Good luck!
Kileen
(3,434 Views)
Thank you Kileen,
exactly what I needed....
Adam
(3,423 Views)
