wavetek 301Giving Time out error
I want to control Wavetek 301 Function generator through GPIB.
I have downloaded the drivers from NI site.
I am able to Quary ID though LAbview using Initializing VI.
Later on in Configuring the waveform output mode it gets busy and gives timeout error.
Following error is getting generated:
wt30x Configure Operation Mode.vi<ERR>
Driver Status: (Hex 0xBFF0015) Time out
expired before operation completed.
Ealaboration: Attribute:
WT30X_ATTR_OPERATION_MODE,channel:CHAN_A
what could be the reason for time out?
(3,332 Views)
       I recommend that you try the steps listed in the Instrument Driver Troubleshooting Guide.
Cheers,
NathanT
(3,320 Views)
