what is meaning this message ?
when i use exe file ....this message which is attached appears
" Science is came....not come "
I study Mechatronics Engineer
skype : t_alhowaiti
Message 1 of 9
(5,094 Views)
Probably the program aborts an io operation and ni is so friendly to reset the driver.
Are you stopping or aborting a program?
These are not the same!
greetings from the Netherlands
Message 2 of 9
(5,068 Views)
i sory for late........
yes i aborts  my program ....
skype : t_alhowaiti
Message 3 of 9
(5,063 Views)
The abort button should not even be visible on the toolbar. Unexpected results can happen.
Message 4 of 9
(5,049 Views)
HOW CAN I STOP ?
skype : t_alhowaiti
Message 5 of 9
(5,044 Views)
With a button on the front panel that then closes everything running in a controlled manner.
And please, don't shout. That is impolite.
Message 6 of 9
(5,039 Views)
in my program i reading datat from serial port ......and if i exit from programm this message will appear .....how can i cancel this message ?
skype : t_alhowaiti
Message 7 of 9
(5,027 Views)
It does not really add to the discussion if you keep attaching the same image over and over, so stop that! Thanks.
Show us your code and tell us exactly how you "exit from the program". The root cause is in your program and how you (ab)use it, not in the dialog you keep showing us.
You cannot cancel that message, but you should be able to clean up your code so it no longer happens. For more information, have a look at this article.
Message 8 of 9
(5,018 Views)
ok ....i will send the code for you in private message
skype : t_alhowaiti
Message 9 of 9
(5,014 Views)
