when data receiving from serial port, a framming error occured
hai, i am deepak from Ernakulam,Kerala.Now my work is based on LabVIEW.A decimal data is contiuesly acquired from a hardware using LabVIEW.But one Framming error occured.How can avoid this problem? I am waiting for your reply... thank you
(3,516 Views)
This depends on the nature of the framing error.
Is your wire correct, Are the line voltages OK. etc.
If it is noise on the line or a hickup in your system, you can retry but most of the time it is a wrong setting on one of the ends of the line.
greetings from the Netherlands
(3,511 Views)
Typically when I get framing errors, it is because I haven't allowed enough time for the serial port either 1)before the first write command, 2)between a set of read and write commands.  Insert an initial, one-time use (not neccessary to loop it) Serial Wait command directly after your Serial Config vi runs, but before your acquisition looping starts.  If that doesn't work, double-check the wait times between successive write and read commands being sent.
And again, this isn't definitely the solution to your problem, but when I get framing errors this is typically the problem.
Good luck.
(3,445 Views)
