where can i get nitypes.h and niimaq.h? can i use pci-1424 through cygwin?
I am trying to access the IMAQ.dll through cygwin but
don't have the two header files -- where can i get them?
I am using a pci-1424 and cygwin on a windows xp laptop.
(the pci-1424 is read via a Magma pci->pcmcia converter).
The g++ compiler doesn't complain when i link-in the
IMAQ.dll in my makefile, but i need the headers before
can know if it will really work. If anyone can give me
advice regarding this approach I'd be grateful! Thanks,
Charlie Cosse
(3,088 Views)
If you have installed the NI-IMAQ driver with C support, you can find those files in the following default path:
C:\Program Files\National Instruments\NI-IMAQ\Include
Hope this helps!
Yusuf C.
Applications Engineering
(3,088 Views)
