why do error comes when trying to use NI ISA GPIb and NI DAQ card (both PnP)together while they work well when one at a time?
we configured gpib pnp and at-mio-64e3 cards (isa) in the same pc.gpib function was invoked to take the device to remote and listen mode.now when daq function getDeviceInfo is called the remote mode of the device is removed and after this it always shows no gpib board until pc is rebooted
(3,079 Views)
I have some questions:
What OS are you using?
What driver versions?. You can find the driver versions in the Windows Add/Remove programs utility. DAQ driver is NI-DAQ anmd GPIB driver is NI-488.2.
Is there any error code?
I haven't found any known issues between these two drivers. How are the board's resources configured? Base address, IRQ, DMA.
Let see if with this information we can clear out what is going on.
DiegoF.
(3,079 Views)
