why viwrite() is not giving error for an invalid command
Hi All,
I have a doubt related to VISA - viwrite().
I am controlling a DC power supply through VISA. I am able to do all the basic operations successfully without any issues.
My concern is :
when i am trying to write some invalid command , say for example "^&$" using viwrite(), it is not throwing any error.viwrite() is returning 0. After viwrite(), i called viread(), then surprisingly in read buffer i got device identification string. Even viread() is also not throwing error.
Then in this case, how i can provide error checking like the command given is an invalid command like that.
Am i missing any thing?
Any small help will be greatly appreciated. and i am using labwindows/CVI 8.5.
Harika.
Message 1 of 9
(4,762 Views)
Why would you expect a VISA error? The write and read were successful. How could VISA know that you sent an invalid instrument command? You do understand that each instrument has a unique command set and that a generic hardware driver such as VISA has no way of knowing what that command set is. What you would need to do is send an error query (i.e. ERR?) to the instrument.
Message 2 of 9
(4,756 Views)
Hi Knutson,
Thanks for your reply.
As you said, i tried with error query but then also it is not returning any error.
This is my code:
 st = viOpenDefaultRM(&vi1);
 st = viOpen(vi1,"Dev2", VI_NULL, VI_NULL, &vi2);
 st = viWrite(vi2,cmd,strlen(cmd),&returncount);
 st = viWrite(vi2,"SYST:ERR?",10,&returncount);
 st = viRead(vi2,value,512,&readCount);
 st = viClose(vi1);
After executing this, "value" variable contains "0,No Error".
Can you please let me know am i missing anything.
Harika
Message 3 of 9
(4,749 Views)
In the above code, cmd contains some invalid command like "%^&".
Message 4 of 9
(4,748 Views)
Then you will have to check with the vendor. You have not provided the make and model.
Message 5 of 9
(4,745 Views)
I am using Sorenson DC Power Supply.
Model is Sorensen DLM 40-15.
Is this issue woth the vendor?
Message 6 of 9
(4,729 Views)
Isn't that what I already said with 'Check with the vendor'?
Message 7 of 9
(4,708 Views)
I doubt the model does not support error query mechanism. You can check with the vendor.
Message 8 of 9
(4,669 Views)
I also think the error processing mechanism in the instrument looks like not working.  It may be a firmware (specially SCPI command parser) issue in the instrument.  Ask the vendor.
Message 9 of 9
(4,646 Views)
