why when i launch a second cvi application and when i make a ViOpen on any instrument the line REN pass from 1 to zero that make my others intruments go to local state?
The easiest workaround for this is to use the viGpibControlREN command found on page 5-43 of NI-VISAProgrammersMan.pdf. This will allow control of the REN line after doing a viOpen.
(3,307 Views)
Yes but in that case i must modifie all my instrument drivers!
Is this a normal way to work ?
is there other way to manage this problem?
is it a known bug of cvi?
(3,307 Views)
